Design Opportunity http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47784 |
Author: | bcombs510 [ Tue May 17, 2016 11:17 am ] |
Post subject: | Design Opportunity |
Hello, I'm not sure how I overlooked this, but there is a purfling mistake on the back of this latest build which is providing a unique opportunity for me to be creative. Below is a pic. I've already put the first coat of z-poxy on so I'm hoping to avoid going backward to try to fix it. Attachment: IMG_0607.JPG My first thought was some type of decorative heel cap that would sit over top of the binding. It would create a bump on the back of the guitar though. Something like this: Attachment: Heel Cap.jpg I'm wondering if anyone has seen a design like this before or if it perhaps has a name (I learned volute recently, maybe this type of heel cap has a special name ![]() The binding scheme is Ebony with w/b strip. I thought about maybe a piece of ebony shaped to cover the area. I was planning to have the heel shape be a D shape, around 12-15mm wide or so. Any hints on the heel cap approach or other ideas how to cover up would be appreciated. Thanks! Brad |
Author: | johnparchem [ Tue May 17, 2016 11:21 am ] |
Post subject: | Re: Design Opportunity |
If I was to fix that I would lift the ends of the bindings using a heat gun and re-glue or just reset while hot so that it lines up. The end gap/design opportunity would make neck resets a real mess finish wise. I will bet you will lose nothing but a bit of time as the zpoxy is still in whatever pores it is in. Looking at the picture you may be able to use a heat gun to heat the high binding and pull it down with tape. PVA is a bit thermoplastic so it will reset. |
Author: | bcombs510 [ Tue May 17, 2016 11:24 am ] |
johnparchem wrote: The end gap/design opportunity would make neck resets a real mess finish wise. Of course! That would be a huge problem to deal with in a neck reset. OK, I will try to fix it then. Thanks for the pointer about the neck reset! |
Author: | Glen H [ Tue May 17, 2016 2:03 pm ] |
More work maybe, but if that fix fails, put in a back center strip of ebony, mitering in with the white. |
Author: | kencierp [ Tue May 17, 2016 5:02 pm ] |
Was this a well executed embellishment or save -- we can't tell so that is a good thing. ![]() |
Author: | Joe Beaver [ Tue May 17, 2016 5:42 pm ] |
I too would go with John's 'fix'. It looks like there is plenty of our purfling material to make it look good |
Author: | dofthesea [ Tue May 17, 2016 9:05 pm ] |
Thats san easy fix. Just scarf in a small piece or use a heat and work it and fix it. Could be as pretty quick fix. |
Author: | Haans [ Sat May 21, 2016 7:15 am ] |
A heel cap like the one you are thinking of would only lead others to wonder what you are covering up. Take a day off and think about it. Then fix it. You have one chance to get it right. |
Author: | Nils [ Sat May 21, 2016 8:14 am ] |
So many times I have tried to make something look a little better, only to make it look a lot worse...I would leave it alone and try not to do it next time. |
Author: | Pmaj7 [ Sun May 22, 2016 1:45 pm ] |
What's going on there? Binding didn't get clamped down or purf channel was to big ? Close up pic? |
Author: | Clay S. [ Sun May 22, 2016 6:32 pm ] |
"I've already put the first coat of z-poxy on so I'm hoping to avoid going backward to try to fix it." Choices: 1. Don't 2. Using a single edge razor blade cut the purfling lines loose, remove a sliver of wood from the back and push the lines into place. 3. Add a back strip 4. Scarf in a small section of purfling I've done all those things at one time or another. All but the first choice can make it look worse (or better). |
Author: | Terence Kennedy [ Sun May 22, 2016 9:29 pm ] |
I have heated and realigned binding in that area. It works. Might have to scrape out some cement with a #11 blade or dental probe to get it aligned. Clamping tight would be easy with a long bar clamp and you could spot glue it with CA under direct vision. That's what I think I'd try. |
Author: | cleanheadsteve [ Wed May 25, 2016 9:12 am ] |
why not just make ur heel cap flush. u can route down the overlap area of the box so the cap fits in nice and snug. (p.s. i've never built a guitar in my life. still working on the basics : ) Sent from my 5054N using Tapatalk |
